willer Friend
willer
- 10 times in 1 posts
willer Friend
willer
willer Friend
willer
willer Friend
willer
willer Friend
willer
June 8, 2015 at 8:46 am #573227Check my PM, I couldn’t access back-end of your site now.
willer Friend
willer
willer Friend
willer
June 9, 2015 at 4:39 am #573390I finally can access your site (with https).
You can try with this tweak to enable sidebar in mobile view:
– Go to file: root/templates/ja_teline_v/local/css/template.css
– Look for this css declaration (at approx line 5092):
@media screen and (max-width: 992px) {
.t3-sidebar {
display: none;
change to display: block;
willer Friend
willer
willer Friend
willer
June 10, 2015 at 1:45 am #573514Of course, you can.
However, as I can see that you also have above css inside the root/templates/ja_teline_v/local folder so there is no need to add to custom.css file. Because all the override inside this local folder will not be affected when you update template.
The reason why we provide this ‘local’ folder while having ‘custom.css’ is that with ‘custom.css’ file, you can override css style only. But with ‘local’ folder, you can also override: less, layout, etc…
Pls check out this documentation for more info: http://www.t3-framework.org/documentation/new-features#isolate-template
June 10, 2015 at 1:45 am #738541Of course, you can.
This topic contains 43 replies, has 3 voices, and was last updated by Saguaros 9 years, 8 months ago.
