test melih
 melih
Viewing 15 posts - 16 through 30 (of 43 total)
  • willer Friend
    #572681
    If I delete that code that I added in the text file custom.css widens to the edge. But the right column is never visible, only on desktop.
    willer Friend
    #737716
    willer Friend
    #572699
    But it’s just my site that has the problem of the right column disappears on mobile devices ?
    willer Friend
    #737734
    You can edit the custom css rule a little bit to:
    @media (min-width: 992px) {
    .col-md-9 {
    width: 71%;
    .col-md-3 {
    width: 29%;
    willer Friend
    #572784
    Thanks @saguaros, works !:D Now there remains the problem of the right column disappears.
    The screen size of mobile is too small so we hide that position in the mobile view.
    If you still wanna show it, you can access administrator area of your site >> Extensions >> Template manager >> select Default template style >> navigate to ‘Layout’ tab >> Responsive layout >> Extra small tab and enable the position you wish in this layout.
    willer Friend
    #572927
    @saguaros the sidebar tab is active, but do not understand why you do not see the column.
    1. scheda-attiva-sidebar
    You can PM me URL and admin login info of your site, I will take a look.
    willer Friend
    #573042
    @saguaros You have a private message…
    willer Friend
    #738075
    willer Friend
    #573259
    @saguaros you have a PM
    willer Friend
    #738287
    willer Friend
    #573260
This topic contains 43 replies, has 3 voices, and was last updated by  Saguaros 9 years, 8 months ago.
