September 5, 2016 at 11:35 am #965731Dear Christina,
Could you provide the login info of your site and specify the page where we can see the issue? http://static.joomlart.com/images/blog/2015/nov/Add-new-post.gif
tineto Friendtineto
- December 2015
- 2 times in 2 posts
September 6, 2016 at 7:23 am #965975This reply has been marked as private.Saguaros ModeratorSaguaros
September 7, 2016 at 2:31 am #966230The admin account doesn’t work, could you check again?
tineto Friendtineto
- December 2015
September 7, 2016 at 7:14 am #966279Sorry, could you please try again.
Christina
September 8, 2016 at 7:49 am #966662You can try to follow this topic: https://www.joomlart.com/forums/topic/glossary-another-language-alphabet/
tineto Friendtineto
- December 2015
September 8, 2016 at 11:13 am #966739I already followed the instructions regarding the content language and front-end language but that doesn’t work. Does the glossary layout works at all with another alphabet except Latin? I mean does the php code makes difference between latin and non-latin characters?
Thanks!
Christina
September 9, 2016 at 2:11 am #966894Dear Christina,
As my colleague explained in that topic, you can try with multilingual site. For example, in our demo site, there is an article for category that glossary page is showing, its name is ‘VAT’, in multilingual site, you will have an associated article in your 2nd language on your site. The same with menu item of glossary page. You can follow the links provided in that topic.
tineto Friendtineto
- December 2015
September 9, 2016 at 7:35 am #966924Right, and in the associated article in my 2nd language on my site it shows what could be seen in the attached file. It just doesn’t recognize the Cyrillic alphabet, ok?
Could you provide a solution for that?Christina
September 12, 2016 at 4:56 am #967500Could you update the admin login info again? It doesn’t work now.
tineto Friendtineto
- December 2015
September 12, 2016 at 7:41 am #967548Done.
September 13, 2016 at 3:45 am #967804I don’t see the associated article of VAT article on your site, did you follow the guide to create multilingual site?
tineto Friendtineto
- December 2015
September 13, 2016 at 3:27 pm #967961I don’t see the associated article of VAT article on your site, did you follow the guide to create multilingual site?
There is a language switcher in the upper left corner of the page.
Thanks,
ChristinaSaguaros ModeratorSaguaros
September 15, 2016 at 1:20 am #968304I meant in settings of that article. You can see Associated tab
tineto Friendtineto
- December 2015
September 15, 2016 at 10:25 am #968468That’s not an article, it’s a Glossary layout page (category of articles).
Thank you for your time, Saguaros!
The conclusion is: the Glossary layout of Purity III works only with Latin alphabet characters.
Regards,
ChristinaAuthorPostsViewing 14 posts - 1 through 14 (of 14 total)This topic contains 14 replies, has 2 voices, and was last updated by tineto 7 years, 7 months ago.
The topic ‘Glossary layout problem with multilingual site’ is closed to new replies.
