August 7, 2017 at 8:20 am #1054170
If I click on a picture of the ["femme"] tab, I will go to the product page
If I click on the image of the tab ["tous"] https://v6.sweetalpaga.com/
, I arrive on an error:0 page
https://v6.sweetalpaga.com/index.php?option=com_virtuemart&view=productdetails&virtuemart_product_id=126&virtuemart_category_id=14
RegardsSaguaros ModeratorSaguaros
August 8, 2017 at 8:50 am #1054440Hi,
Did you try to assign the menu item that category belongs to to a standard template of Joomla like Beez/Protostar and see how it goes?
August 8, 2017 at 12:20 pm #1054484Hi, I looked but it did not change anything. In fact I realize that this is not related to the module tabs for the same problem also appears from the woman https://v6.sweetalpaga.com/index.php?option=com_virtuemart&view=category&virtuemart_category_id=14&virtuemart_manufacturer_id=0&Itemid menu = 648 = 0 & limitstart if I click on the product: "Veste longue alpaga ardoise" I fall on the same error 🙁 : https://v6.sweetalpaga.com/index.php?option=com_virtuemart&view=productdetails&virtuemart_product_id=69&virtuemart_category_id=14&Itemid=648
It seems to me that this entry appears on some catégérories VM (in any case, the latter comprising several subcategories.
At first I thought it was the featured products (or with a label: new) but a priori no. This is really the biggest problem found !!
- This reply was modified 6 years, 8 months ago by hdcms.
August 9, 2017 at 6:35 am #1054636You can share the admin + FTP account so I can check it further.
August 9, 2017 at 8:42 am #1054700This reply has been marked as private.August 10, 2017 at 7:23 am #1054930Hello,
Did you watch?
I will have to finish this site this week because after I’m absent 15 days.
Thank you for helping me to close these 2 problems (including https://www.joomlart.com/forums/topic/virtuemart-9/ ) very strange
August 11, 2017 at 6:54 am #1055814Hi,
Could you clear browser’s cache & cookies and check this page now? https://v6.sweetalpaga.com/index.php/femme
I open some products from this page and it works
August 11, 2017 at 8:03 am #1055843HI, Unfortunately this does not work. Did you see that it was some products that did not work? These are essentially women’s jackets like
https://v6.sweetalpaga.com/index.php/femme/veste-longue-ardoise-detail
Regards- This reply was modified 6 years, 8 months ago by hdcms.
August 11, 2017 at 12:18 pm #1055916Hello,
I know this is more difficult than proposing a CSS addition, but can you move forward? Is it possible by this evening? I am really embarrassed with these 2 difficult points. Thank you for your help!
August 17, 2017 at 2:34 am #1056892Hi,
I just udpated:
In the file: root/templates/ja_megastore/html/com_virtuemart/productdetails/default.php
At approx line 256, where there is condition to show child categories and I replaced:
if (VmConfig::get('showCategory', 1)) { echo $this->loadTemplate('showcategory'); }
by this:
if ($this->cat_productdetails) { echo $this->loadTemplate('showcategory'); }
And it’s working now.
August 21, 2017 at 2:33 pm #1057680HI,
Thanks for the fix. Will it be included in the next update or will it be necessary that I copy it after updating the theme?
Unfortunately, since this fix, a new problem has appeared; If I click on a thumbnail, the corresponding image does not appear on the page
Ex:
https://v6.sweetalpaga.com/index.php/femme/echarpe-alpaga/ines-echarpe-torsadee-noire-detailRegards
August 22, 2017 at 6:53 am #1057858I just tried to revert the change but the same issue happens, it’s not due to above change. Is there any recent update?
August 22, 2017 at 7:26 am #1057868Hi,
Sorry I was wrong about topic!
I can not work on the project for 10 days. The only other modification is the resolution of this other problem:
August 23, 2017 at 7:58 am #1058094I replied in that topic: https://www.joomlart.com/forums/topic/virtuemart-9/page/2/#post-1058093
This topic contains 15 replies, has 2 voices, and was last updated by Saguaros 6 years, 8 months ago.
