March 20, 2008 at 10:00 pm #126785
http://www.edgesolutionsinc.net/index
The slideshow just quit working. I think it was working when I first installed via quickstart, but somewhere between enabling SEO url’s and messing with content it just stopped.
March 21, 2008 at 5:21 pm #242800Umm…Mods and Admins…..hello! Paying customer here, can I get a little help?
jimg Friendjimg
- June 2007
- 10 times in 3 posts
March 21, 2008 at 6:05 pm #242803Hi,
Not a mod, but i think i see the problem. Try changing the ja_slideshow module parameter “include mootools library” to no & save.
Why? your page is throwing the following javascript error:
JaSlideshowClass is not defined
http://www.edgesolutionsinc.net/index/
Line 165Which points to the following section:
<script type="text/javascript" src="http://www.edgesolutionsinc.net/index//modules/mod_jaslideshow/ja_slideshow/mootools.v1.1.js"/>
Which is returning a 404 error.
Note the double slash after index…
Good luck!
(btw, found this quickly by using firebug – would suggest downloading a copy at http://getfirebug.com )
March 21, 2008 at 6:18 pm #242805Thanks for the help, bro!
Still not working though. I am downloading Firebug atm, so we’ll so what I can find. Any other ideas?
March 21, 2008 at 6:24 pm #242808JaSlideshowClass is not defined
[Break on this error] JaSlideshow = new JaSlideshowClass({Thats the error firebug is finding.
jimg Friendjimg
- June 2007
March 21, 2008 at 6:58 pm #242810Hmmm – here is what i see:
The template – specifically JA_Slideshow – is attempting to load the following file but cannot..
Here is the request:
<script type="text/javascript" src="http://www.edgesolutionsinc.net/index/modules/mod_jaslideshow/ja_slideshow/ja-slideshow.js"/>
And here is the response:
<!DOCTYPE HTML PUBLIC "-//IETF//DTD HTML 2.0//EN">
<HTML><HEAD>
<TITLE>404 Not Found</TITLE>
</HEAD><BODY>
<H1>Not Found</H1>
The requested URL /index//modules/mod_jaslideshow/ja_slideshow/ja-slideshow.js was not found on this server.<P>
<HR>
<ADDRESS>Apache/1.3.39 Server at www.edgesolutionsinc.net Port 80</ADDRESS>
</BODY></HTML>
The file is there… I can see it at http://www.edgesolutionsinc.net/index/modules/mod_jaslideshow/ja_slideshow/ja-slideshow.js
so (IMHO) its a code error in mod_jaslideshow.php that affects those who have an installation outside of the root. In my case, I didn’t have the same problem you had because http://domain.com//module/dir would resolve even with the malformed URI, while http://domain.com/subdir//module/dir would not.
Try this (no guarantees – back up what you have!) version of jaslideshow.php – see if it works for you.
<?phpdefined( '_JEXEC' ) or die( 'Restricted access' );
$folder = $params->get( 'folder', 'images/stories/fruit' );
$mootools = $params->get('mootools',1);
$swidth = $params->get( 'swidth', 430 );
$sheight = $params->get( 'sheight', 200 );
$altimage = $params->get( 'altimage', 'JA Slideshow - http://www.joomlart.com' );
$orderby = $params->get( 'sortCriteria', 0);
$sort = $params->get( 'sort', '1');
$setimagearray = $params->get( 'setimagearray', '');
$startwith = $params->get( 'startwith', 0);
$autoresize = $params->get( 'autoresize', 0);
$timedisplay = $params->get( 'timedisplay', 9000 );
$timeanimation = $params->get( 'timeanimation', 2000);
$animation = $params->get( 'animation', 'combo');
$ppercent = $params->get( 'ppercent', 10);
$zpercent = $params->get( 'zpercent', 10);
$effect = $params->get( 'effect', 'bounceOut');
$showCaption = $params->get( 'showCaption', 1 );
$showmode = $params->get( 'showmode', 0 );
$navigation = $params->get('navigation',"");
$showDescription = $params->get('showDescription',0);
$descriptions = $params->get('description',"");
$play = $params->get('play',"play");
if($showDescription){
global $iso_client_lang;
$descriptionArr = preg_split('/<lang=([^>]*)>/', $descriptions , -1 , PREG_SPLIT_NO_EMPTY | PREG_SPLIT_DELIM_CAPTURE);
$description = '';
if(count($descriptionArr) > 1){
for($i=0;$i<count($descriptionArr);$i=$i+2){
if($descriptionArr[$i] == $iso_client_lang){
$description = $descriptionArr[($i+1)];
break;
if(!$description){
$description = $descriptionArr[1];
else{
$description = $descriptionArr[0];
$description = str_replace("<br />", "n", $description);
$description = explode("n",$description);$descriptionArray = array();
foreach($description as $desc){
//~ $list = explode(":", $desc , 2);
//~ $descriptionArray[$list[0]] = $list[1];
if ($desc) {
$list = split(":", $desc, 2);
$list[1] = (count($list) > 1) ? split("&", $list[1]) : array();
$temp = array();
for ($i = 0; $i < count($list[1]); ++$i) {
$l = split("=", $list[1][$i]);
$temp)] = trim($l[1]);
$descriptionArray[$list[0]] = $temp;
$folder = checkURL($folder);
if(!$folder){ echo "This folder doesn't exist."; }
else{
if (trim($setimagearray) != "") $images = explode(",", $setimagearray);
else $images = getFileInDir($folder, $orderby, $sort );
if (count($images) > 0) {
$imgcount = 0;
$firstImage = '';
$transDetails = '';
$captionDetails = '';
$imageArray = array();
$captionArray = array();
$listDescription = "";
foreach($images as $img) {
if ($imgcount++ == 0) {
if ($startwith)
$firstImage = $folder . $startwith;
else
$firstImage = $folder . $img;
$imageArray[] = "'$img'";
if($showDescription) {
$captionsArray[] = (isset($descriptionArray[$img]) && isset($descriptionArray[$img]['caption'])) ? str_replace("'", "'", $descriptionArray[$img]['caption']) :'';
$urlsArray[] = (isset($descriptionArray[$img]) && isset($descriptionArray[$img]['url'])) ? $descriptionArray[$img]['url'] :'';
if ($showDescription) {
$listCaption = " captions: ['" . implode("','", $captionsArray) . "'],";
$listURL = " urls: ['" . implode("','", $urlsArray) . "'],";
if ($mootools) { echo '<script src="'.JURI::base().'modules/mod_jaslideshow/ja_slideshow/mootools.v1.1.js" type="text/javascript"></script>' . "n"; }
if (trim($animation) == 'push' or trim($animation == 'wipe')) $transDetails = "transition: Fx.Transitions.$effect";
else $transDetails = "transition: Fx.Transitions.sineInOut";
echo '<script src="'.JURI::base().'modules/mod_jaslideshow/ja_slideshow/ja-slideshow.js" type="text/javascript"></script>' . "n";
$linktag = '<link href="'.JURI::base().'modules/mod_jaslideshow/ja_slideshow/ja-slideshow.css" rel="stylesheet" type="text/css" />';
JHTML::stylesheet('ja-slideshow.css', JURI::base().'modules/mod_jaslideshow/ja_slideshow/');$buffer = ob_get_contents();
$pos = strpos ($buffer, '</head>');
if (!strpos ($buffer, "ja-slideshow.css") && $pos) {
$buffer = substr ($buffer, 0, $pos) . "n$linktagn". substr($buffer, $pos);
ob_clean();
echo $buffer;
echo '<div id="ja-slideshow-wrap">' . "n";
echo '<div id="ja-slideshow-case" class="ja-slideshow-case">' . "n";
echo '<img src="' . $firstImage . '" alt="' . $altimage . '" title="' .$altimage. '" />' . "n";
echo '</div>' . "n";
echo '<div id="ja-slidebar" class="ja-slidebar">' . "n";
echo '</div>' . "n";?>
siteurl: '<?php echo JURI::base(); ?>',
type: '<?php echo $animation; ?>',
pan: '<?php echo $ppercent; ?>',
zoom: '<?php echo $zpercent; ?>',
width: <?php echo $swidth; ?>,
height: <?php echo $sheight; ?>,
url: '<?php echo $folder; ?>',
images: [<?php echo implode(",", $imageArray); ?>],
<?php if (isset($listCaption)) echo $listCaption; ?>
<?php if (isset($listURL)) echo $listURL; ?>
duration: [<?php echo $timeanimation*1000; ?>, <?php echo $timedisplay*1000; ?>],
<?php echo $transDetails; ?> ,
navigation: '<?php echo $navigation; ?>',
resize: <?php echo $autoresize; ?>,
classes: ['prev', 'next', 'active'],
play : <?php echo "'$play'"; ?>,
thumbnailre: [/./, 't.']
</script>
<?php
function getFileInDir($folder, $orderby, $sort){
$imagePath = JPATH_SITE ."/".$folder;
$imgFiles = JFolder::files( $imagePath );
$folderPath = $folder .'/';
$imageFile = array();
$i = 0;
foreach ($imgFiles as $file){
$i_f = $imagePath .'/'. $file;
if ( eregi( "bmp|gif|jpg|png|jpeg", $file ) && is_file( $i_f ) ) {
$imageFile[$i][0] = $file;
$imageFile[$i][1] = filemtime($i_f) ;
$i++;
$images = sortImage($imageFile, $orderby , $sort);
return $images;
function sortImage($image, $orderby , $sort){
$sortObj = array();
$imageName = array();
if($orderby == 1){
for($i=0;$i<count($image);$i++){
$sortObj[$i] = $image[$i][1];
$imageName[$i] = $image[$i][0];
else{
$sortObj[$i] = $image[$i][0];
$imageName = $sortObj;
if($sort == 1) array_multisort($sortObj, SORT_ASC, $imageName);
elseif($sort == 2) array_multisort($sortObj, SORT_DESC, $imageName);
else shuffle($imageName);
return $imageName;
function checkURL($url){
if(is_dir($url)){ $url = (substr($url,-1,1) == "/") ? $url : $url."/"; return $url; }
else { return false; }
1 user says Thank You to jimg for this useful post
This topic contains 7 replies, has 2 voices, and was last updated by jmartinez 16 years, 2 months ago.
