July 18, 2017 at 12:02 pm #1049505
I have an issue with JA builder. Everything is working well on the computer browser, but when I’m using a mobile phone there are some issues on some pages.
As you can see here:
if you browse this in a smartphone: http://standbypics.com/index.php/blog/10-tips-to-improve-your-photography-skills
there is a bunch of white spaces on the right side
this made some of the contents behave without the "response" interface feature when I use the JCE editor as you can see here:
http://standbypics.com/index.php/blog/photography-basic-concept
what can I do to eliminate this white space?
Many thanks Fabio
- This topic was modified 6 years, 10 months ago by bybloo.
Saguaros ModeratorSaguaros
July 19, 2017 at 2:19 am #1049674Hi Fabio,
Here is how it looks on my phone. Could you share screenshot of how you want it should be?
July 20, 2017 at 5:01 pm #1050250Hi Saguaros,
thanks a lot for your reply. The problem is actually there. If you slide on the right side you see a bunch of spaces, you can see this also zooming out (see the image below). In this page, I didn’t use the JCE editor, but If you go to the other link you see what happens:
this is due to the fact that somehow JCE editor adapts to the space present on the web page (sorry for the no technical explanation). There are those extra spaces on the right side. I cannot get rid of it.
do you have some ideas? Thanks really a lot
Regards, Fabio
- This reply was modified 6 years, 10 months ago by bybloo.
July 21, 2017 at 7:09 am #1050352Hi Fabio,
Could you share the credentials of your site so I will take a look at the settings?
July 21, 2017 at 8:38 am #1050387This reply has been marked as private.Saguaros ModeratorSaguaros
July 24, 2017 at 3:16 am #1050930Hi Fabio,
The problem comes from the images / slide you added into that blog post: http://standbypics.com/index.php/blog/photography-basic-concept
in which they are set with a fixed dimension: width: 665px; height: 480px; so in mobile view port, it breaks the layout.
AuthorPostsViewing 6 posts - 1 through 6 (of 6 total)This topic contains 5 replies, has 2 voices, and was last updated by Saguaros 6 years, 10 months ago.
