kella@youngerusa.com Friend
- January 2016
February 3, 2016 at 8:51 pm #875749I am using RSTickets Pro as a ticket system. When I click on the "Services" tab of my main menu and choose "Ticket System" the Menu button turns blue.
Also, the search within the ticket system seems to be having some errors. I do not experience this with other templates.
I have attached an image of what it looks like.
Can you please help?
Saguaros ModeratorSaguaros
February 4, 2016 at 4:14 am #875969Hi
Seems that the RsTicket Pro uses old Bootstrap version and it also use the same classes used in this template so that it causes the conflict.
Uber template or most template built with T3 framework are using Bootstrap 3, pls try to contact provider of RsTicket Pro if they supports Bootstrap 3 or not.
kella@youngerusa.com Friendkella@youngerusa.com
- January 2016
February 5, 2016 at 3:44 pm #877325Thank you, it seems that RSTickets Pro only supports the Joomla official Bootstrap version 2.3.2. but they also said I can add it myself through Template overrides and source code modification. Would you be able to help me with this?
February 9, 2016 at 9:48 am #879807To override extension via template, it can be done via directory: ROOT/templates/uber/html/
For more info, pls check out this docs: https://docs.joomla.org/How_to_override_the_output_from_the_Joomla!_core
- January 2016
February 10, 2016 at 3:51 pm #880824Thank you for the information but I am very new to bootstrap. I am not sure what I need to override. I have no idea where to even start.
Edit: I think I was able to fix this problem. Thank you for your help.
February 11, 2016 at 2:41 am #881078Glad to hear you figured it out!
AuthorPostsViewing 6 posts - 1 through 6 (of 6 total)This topic contains 5 replies, has 2 voices, and was last updated by Saguaros 8 years, 3 months ago.
Problem Integrating with RSTickets Pro
