  • zabetas93 Friend
    #1050201
    During the installation of ja builder I am receiving the following:
    An error has occurred.
    0 Database error - You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near '' at line 3
    Problem Solved.
    • This topic was modified 6 years, 9 months ago by  zabetas93.
    Do you mean this issue happen when installing in admin panel?
    Could you take a backup of your site so I will try to install?
    zabetas93 Friend
    #1050400
    Hi Saguaros, i took a backup of my site, you can try to install. Thanks for helping me
    zabetas93 Friend
    #1050628
    Problem Solved.
    I ran the debug console of Joomla and the problem was caused by RocketTheme RokUpdater Plugin. I disabled it and the installation completed successfully.
    Thanks a lot
    Glad to hear that it’s solved now.
This topic contains 4 replies, has 2 voices, and was last updated by  Saguaros 6 years, 9 months ago.
