I am using JAComment and it appears when titles contain certain characters, for example : or #, the plugin breaks and doesn’t correctly process the entry.
The code that I am using in the component in question is:
[PHP]{jacomment contentid=$item->id option=com_mycom contenttitle=$item->title }”;[/PHP]
JAComment works on the vast majority of entries, but it goes unprocessed on pages where the content contains punctuation.
I see that in the jacomment.php content plugin file, there is a line:
[PHP]var $_plgCode = “#{JAComment(.*?)}#i”;[/PHP]
I assume this is where the regex comes from.
Can anyone see why the plugin is failing when the title contains certain characters (by the way, I tried using preg_quote() on the output in my component, but that didn’t help at all.
