  • laoracion Friend
    #971503
    My problem is this.
    If i setup show introtext- site show 2 times introtext. And if i setup to do not show introtex then i cannot see the introtext when seeing an specific article.
    So if i share an url linking to an specific article i cannot read the begining.
    is it clear????
    main url
    http://www.la-oracion.com/index.php
    http://www.la-oracion.com/blog/como-orar/515-arder-por-dentro-o-quemar-por-fuera (specific article)
    Youl see twice this
    Las dos cosas: arder por dentro y quemar por fuera. El fuego tiene que estar encendido o no es fuego. Obvio.
    (introtext)
    If i disabled introtext so .. i cannot read it.
    Could you update the login info so I will have a look?
    laoracion Friend
    #971842
    I edited the file: ROOT/templates/ja_telinev/html/layouts/joomla/content/item/default.php
    By changing:
    <section class="article-content" itemprop="articleBody">
    <?php echo JLayoutHelper::render('joomla.content.info_block.topic', array('item' => $item)); ?>
    <?php echo $item->text; ?>
    to:
    <?php echo $item->fulltext; ?>
This topic contains 3 replies, has 2 voices, and was last updated by  Saguaros 7 years, 7 months ago.
