February 28, 2012 at 9:20 pm #174411
when ever I try to install JA Teline IV it shows me like this this message
You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near ‘TYPE=MyISAM AUTO_INCREMENT=12’ at line 29 SQL=CREATE TABLE `jos_banner` ( `bid` int(11) NOT NULL AUTO_INCREMENT, `cid` int(11) NOT NULL DEFAULT ‘0’, `type` varchar(30) NOT NULL DEFAULT ‘banner’, `name` varchar(255) NOT NULL DEFAULT ”, `alias` varchar(255) NOT NULL DEFAULT ”, `imptotal` int(11) NOT NULL DEFAULT ‘0’, `impmade` int(11) NOT NULL DEFAULT ‘0’, `clicks` int(11) NOT NULL DEFAULT ‘0’, `imageurl` varchar(100) NOT NULL DEFAULT ”, `clickurl` varchar(200) NOT NULL DEFAULT ”, `date` datetime DEFAULT NULL, `showBanner` tinyint(1) NOT NULL DEFAULT ‘0’, `checked_out` tinyint(1) NOT NULL DEFAULT ‘0’, `checked_out_time` datetime NOT NULL DEFAULT ‘0000-00-00 00:00:00’, `editor` varchar(50) DEFAULT NULL, `custombannercode` text, `catid` int(10) unsigned NOT NULL DEFAULT ‘0’, `description` text NOT NULL, `sticky` tinyint(1) unsigned NOT NULL DEFAULT ‘0’, `ordering` int(11) NOT NULL DEFAULT ‘0’, `publish_up` datetime NOT NULL DEFAULT ‘0000-00-00 00:00:00’, `publish_down` datetime NOT NULL DEFAULT ‘0000-00-00 00:00:00’, `tags` text NOT NULL, `params` text NOT NULL, PRIMARY KEY (`bid`), KEY `viewbanner` (`showBanner`), KEY `idx_banner_catid` (`catid`) ) TYPE=MyISAM AUTO_INCREMENT=12
what is the problem I have download latest version from you download section and still it did not work
TomC ModeratorTomC
- October 2014
- 3155 times in 2495 posts
February 28, 2012 at 10:34 pm #440720Which method are you using to upload your template files to your server?
March 1, 2012 at 7:16 am #441047I am using Auto, the ftp I am using is Filezilla Ftp
TomC ModeratorTomC
- October 2014
March 1, 2012 at 11:48 pm #441236<em>@axadle 304123 wrote:</em><blockquote>I am using Auto, the ftp I am using is Filezilla Ftp</blockquote>
Okay, so you are uploading your template files via FileZilla FTP … good.Is this a quickstart package installation and, if so, are you following the steps outlined within THIS TUTORIAL ??
This topic contains 4 replies, has 2 voices, and was last updated by TomC 12 years, 2 months ago.
