I’ve installed the template Joomla Purity III, I’ve installed also the T3 plugin and the component JA Extension Manager. I put Purity as predefined template but I when I go on my website’s frontend I have this error message:
Warning: require_once(T3_TEMPLATE_PATH/helper.php): failed to open stream: No such file or directory in /web/htdocs/www.bbnottimagiche.net/home/templates/purity_iii/html/com_content/article/default.php on line 15
Fatal error: require_once(): Failed opening required ‘T3_TEMPLATE_PATH/helper.php’ (include_path=’.:/php5.6/lib/php’)in /web/htdocs/www.bbnottimagiche.net/home/templates/purity_iii/html/com_content/article/default.php on line 15
With other templates this didn’t happened.
I have Joomla 3.6.5, PHP version 5.6.30
Thank you for the support!
Anna Delia
