  • anilvc31 Friend
    #939279
    Dear Sir ,
    How can I relocate mainmenu module above the component and side bars in default configuration (4). Further I want one more mainmenu module at the top most position.
    Kindly guide and help me to achieve the same.
    Thanking you
    With best regards
    Anil V. Chaudhary
    Pankaj Sharma Moderator
    #939297
    You can see how the main nav and header is defined in the tpls/blocks folder . And make customizations .
    with help of this doc : http://www.t3-framework.org/documentation/customization.html
    And you can also create new blocks with help of this doc : http://www.t3-framework.org/documentation/bs3-layout-system#add-block
This topic contains 1 reply, has 2 voices, and was last updated by  Pankaj Sharma 7 years, 11 months ago.
