  • Eddy Tippet Friend
    #922664
    I would like to create and overlay a module position over top of the Masthead position.
    The purpose is to display a Facebook Like Button in the lower right hand corner of a rotating banner in the Masthead position.
    I’m tweaking code with methods I found on some forums:
    Joomlart.com: Overlay Position…
    DigitalPoint.com: Overlapping modules in Joomla
    But I’m not having to much luck on getting it to work.
    Any help would be greatly appreciated!
    Pankaj Sharma Moderator
    #922741
    This is custom work request . You can give me screenshot and illustrate the matter inside it , what u want to achieve so i can help u in this matter . The link you provided above is too old and not for the T3 framework .
This topic contains 1 reply, has 2 voices, and was last updated by  Pankaj Sharma 8 years ago.
