test melih
 melih
  • orlandom2013 Friend
    #1022321
    Hi, thanks for your mega template! i´m using in my new Shoe shop site but i nead your help.
    Like other shoe shop, i´ve many color variations for the same SKU and i need a plugin to help users… i found "Color Swatch" and i´ve a licence (not cheap) but when i try to put it working in megastore template the zoom feature do not work, this is the link too the product at developmente site:
    http://godiva.pt/dev/senhora/sapatos/sandalias/223/sand-lia-9-detalhe.html
    This is the Color Swatch plugin demo that i need to iqual:
    http://preview.cmsmart.net/demo/virtuemart-color-swatch-extension
    JED:
    https://extensions.joomla.org/extension/color-swatch-for-virtuemart/
    Please point me the right direction. I nead to finish this shop asap!
    Thanks in advance
    As I can see that it’s working now, did you get it solved?
    orlandom2013 Friend
    #1022643
    Hi, it´s not solved, we´re trying to get this working other way no zoom function works with this plugin.
    Now i need to lunch this shop but i will need to find what´s the problem, if you find a reason, please help me.
    Did you try switch default template to Protostar or Beez – standard template of Joomla and see how it goes?
    I tried to access admin panel of your site but it seems that the provided account doesn’t work.
This topic contains 3 replies, has 2 voices, and was last updated by  Saguaros 7 years, 10 months ago.
