pfchute Friend
pfchute
- February 2007
- 2 times in 1 posts
October 17, 2008 at 12:57 pm #134520Hi I am wanting to use this template with Virtuemart but im having a problem with the JA News Frontpage Module showing underneath the all the shop pages.
Is there a way so it only shows on the home page?
Im running Joomla 1.0 with + Virtuemart 1.1 if that helps
pfchute Friend
pfchute
- February 2007
October 17, 2008 at 2:53 pm #275876Problem 1 solved. Simply create a link to the Virtuemart componant in the main menu.
Problem 2 – Lightbox image pop up obscured by the menu bar of the tamplate
can be veiwed here http://www.activesteps.co.uk/index.php?page=shop.product_details&flypage=flypage.tpl&product_id=6&category_id=1&option=com_virtuemart&Itemid=46
This is a test domain i have so play around to your hearts content. Any ideas on how to solve this
pfchute Friend
pfchute
- February 2007
October 17, 2008 at 2:59 pm #275877A better example of the problem is available here http://www.activesteps.co.uk/index.php?page=shop.product_details&flypage=flypage.tpl&product_id=17&category_id=2&option=com_virtuemart&Itemid=46
Please clcik on the large image link
tonyg Friend
tonyg
- June 2008
- 46 times in 27 posts
October 17, 2008 at 5:07 pm #275908Hi
You need to edit your lightbox css look here for my solution to a previous post; http://www.joomlart.com/forums/showthread.php?p=79529#post79529
tonyg 16 years, 3 months ago.
Virtuemart Problem
