June 15, 2011 at 6:48 pm #165258
Using Teline IV 1.2.4
Joomfish 2.1.7When I switch language(en/fa) using joomfish, template mode dose not change and stays LTR.
Please Advise.
Thanks.
kshama_k Friend
kshama_k
- May 2011
- 11 times in 10 posts
June 16, 2011 at 2:18 pm #396704hi
i have checked your site ,when i change the laguage (fa) then it show RTL, your site works fine.
please see i have attached a screen shot of your site.-
June 20, 2011 at 1:39 pm #397413
Good morning,
You are looking at the wrong site, here is the correct http address:
http://www.immigrace.com/dev4/
Joomfish 2.1.7Click on the flag, it does not switch.
Please advise.
Thanks.chavan Friend
chavan
- October 2014
- 1440 times in 1290 posts
June 21, 2011 at 7:41 am #397569Hi jamtavasoli
I tried to check the site but don’t see the issue, it works fine. Check my attachment please!
June 21, 2011 at 5:19 pm #397689<em>@dohq 248572 wrote:</em><blockquote>Hi jamtavasoli
I tried to check the site but don’t see the issue, it works fine. Check my attachment please!</blockquote>
The above attachment image is not right. please try switching to RTL mode using “CPANEL” and you will see the difference.
Attached please find two attachments for comparison:
– RTL mode using manual selection of RTL in CPANEL (cpanel.jpg) which is perfect
– RTL mode when switching to RTL by joomfish (joomfish.jpg) which is not goodFor some reason when I switch to RTL using joomfish it dose not switch the template to RTL mode completely.
Please advice.
chavan Friend
chavan
- October 2014
June 22, 2011 at 2:35 am #397737Hi jamtavasoli
Could you give me ftp account of your site via JXA-212-52767 ?
June 22, 2011 at 4:59 pm #397892<em>@dohq 248782 wrote:</em><blockquote>Hi jamtavasoli
Could you give me ftp account of your site via JXA-212-52767 ?</blockquote>
Done.
Thanks.
chavan Friend
chavan
- October 2014
June 23, 2011 at 6:38 am #397973Hi jamtavasoli
The “RTL” when you change language is a direction but the “RTL” in cpanel is a T3 profile.
Therefore when you change language, direction will be changed but not profile.
There isn’t a feature in T3 associate language with profile. We will consider this feature in next version of T3.
June 23, 2011 at 11:26 pm #398123<em>@dohq 249071 wrote:</em><blockquote>Hi jamtavasoli
There isn’t a feature in T3 associate language with profile. We will consider this feature in next version of T3.</blockquote>
I do not believe you can categorize this as a feature, in my opinion this is a bug. A functional RTL template should work when users switches the language, no buts or ifs or partial switch!
Dont you agree?
Please keep in mind that this is working fine with other JA templates that offer RTL.
Please advise.
chavan
- October 2014
June 24, 2011 at 8:08 am #398176<em>@jamtavasoli 249263 wrote:</em><blockquote>I do not believe you can categorize this as a feature, in my opinion this is a bug. A functional RTL template should work when users switches the language, no buts or ifs or partial switch!
Dont you agree?
Please advise.
Thanks.</blockquote>I don’t think so. I give you an example:
When you access your website via http://www.yourwebsite.com?direction=rtl, result is similar when you change language.
And if it is http://www.yourwebsite.com?profile=rtl, result is similar when you change in cpanel.July 5, 2011 at 3:11 pm #399980Hello,
In that case, can you help me figure out how to get joomfish to switch profiles, when switching language? Is there a hack available to link T3 profile to the language, until you guys implement this feature in the next version?
As you have concluded yourself, at the movement switching to any language with RTL requierments (Hebrew, Persian, Arabic,…) using Joomfish will not work in this template.
Thanks in advance.
BigHug Friend
BigHug
- September 2012
- 11 times in 1 posts
July 6, 2011 at 3:40 am #400028Hi jamtavasoli
When you update T3, all customizations may be lost.
You can do as following step:
1. Open file plugins/system/jat3.php
2. Find function onAfterRoute()
3. Add this code
$lang = JRequest::getVar('lang');
if (!empty($lang)) {
$lang =& JFactory::getLanguage();
if ($lang->isRTL()) {
JRequest::setVar('profile', 'rtl');
} else {
JRequest::setVar('profile', 'default');
above
//load core library
T3Framework::t3_init ( $this->plgParams );
Note: if you delete rtl profile, it’ll not work.
1 user says Thank You to BigHug for this useful post
July 6, 2011 at 1:47 pm #400121Thanks a million dohq.
It worked like a charm.
Best.
Viewing 13 posts - 1 through 13 (of 13 total)This topic contains 13 replies, has 4 voices, and was last updated by
jamtavasoli 13 years, 7 months ago.
