test melih
 melih
  • yuriy2015 Friend
    #978470
    I tried to set quick package on the local and remote servers. In each case I can not complete the installation. Always (after clicking on the button "install") going back to the last screen of the installation process . No error messages occurs.
    1. JA-Magz-II-for-3x
    Pankaj Sharma Moderator
    #978475
    Can u share the PHP configurations of your server ?
    Max execution time , memory limits , PHP Version , The package is working fine on my localhost no issue found .
    yuriy2015 Friend
    #978536
    Two points:
    • Quick package JA Teline V was installed on a local server without problems (as a test).
    • But there was a problem with the quick package JA Magz II for 3x, not only on a local, but on a remote server.
    local server configuration files attached.
    https://cloud.mail.ru/public/7EJ2/YmPPKgjXP
    #978817
    Kindly increase the max execution time to 300 , and then download fresh quickstart package , create a new DB with collation : utf-8-gerneral ci .
    Then install the package with sample data and wait for completion of process .
    Hope it helps .
This topic contains 3 replies, has 2 voices, and was last updated by  Pankaj Sharma 8 years, 3 months ago.
