test melih
 melih
  • spoonbow Friend
    #195952
    Good day,
    I’m having some difficulty getting submenus to display under Megamenu. The submenu indicator (down arrow icon) is present next to the menu item, and hovering over the item results in the submenu indicator showing up below the mainmenu section, but the menu is not displayed (see image). Joomla 2.5.16
    Thank You
    Matt
    1. Fullscreen-capture-3192014-45749-PM
    spoonbow Friend
    #527725
    Additional information – I installed the quickstart on the same server and have been comparing the two sites. As far as I can determine, I have correctly configured Megamenu on my custom site. When using Chrome’s developer tools, I see on the quickstart site that the li element containing the menu item changes class from “dropdown mega” to “dropdown mega open” on hover. I do not see this behavior on my custom site when hovering over a menu item with a submenu. It is almost as if Megamenu is not aware of the submenu. Have I missed a configuration step?
    Thanks,
    Matt
    chavan Friend
    #527737
    There are some javascript conflict, which occurred due to arisexylightboxlite plugin, this plugin has very old jquery version.
    So, I have disabled this plugin to fix the issue.
    If you enable this plugin again, the menu and other template related javascript functionality will not work.
    So, now you need to upgrade this arisexylightboxlite plugin
    spoonbow Friend
    #527753
    Ah, my apologies. I should have thought to check the other plugins. Thank you very much for your kind assistance.
This topic contains 4 replies, has 2 voices, and was last updated by  spoonbow 10 years, 10 months ago.
