September 23, 2016 at 5:04 pm #970592
Good evening, I have a problem with Purity III. I am creating a new website so downloaded purity III on joomla (last version). (I already did a website with purity and the older version of joomla and did have this issue). I create a new style with theme magic then save it. My problem is that when I go in the style section, except the defaut style , all the style are written as follow (patch to the file) : I can not change it and if I select it, it doesn’t work… how can I do (I am currently working under wamp server) path are : c:wampwwwmywebsitetemplatespurityIII-mystylelessthemes/mystyle thank you in advance for your help
October 31, 2016 at 10:23 am #982026Unfortunatly I can not…
I reinstalled all : joomla, T3 , purity and again : same thing : it shouldn’t be links to the files but names of the styles… and it can not work as the paths are wrong because of the …
instead of themes : orange red
I have themes c:wampwwwpiratestemplatespurity_pirateslessthemes/orange … same for red…
it doesn’t come from a change I did : it appears this way as soon as I installe Purity…Saguaros Moderator
November 1, 2016 at 12:20 am #982198Are you using the latest version of T3 framework? Try to download again and install into your site.
November 2, 2016 at 10:57 pm #982972It probably isn’t working because you’re using the latest version lol. Mine is so buggy I can’t even modify, change, or save styles. I remember using T3 in the past and not having any unsolvable issues with ThemeMagic but it’s not even working. And the amount of information there is on the latest version of T3 with ThemeMagic is next to nothing.
November 15, 2016 at 1:53 am #986345When you modify / make change to the template style, try to check with Inspect Element in Chrome or Firebug in Firefox and see whether there is any issue or not.
This topic contains 5 replies, has 3 voices, and was last updated by Saguaros 8 years, 2 months ago.
