August 28, 2013 at 7:54 pm #190124
I have tried so many times to install JA Fixel template using Quickstart on my live website and localhost.
Unfortunately, every time I install it, it comes empty! Nothing is there, no Joomshopping, no Shop, no nothing!I have even tried to install the Joomshopping extension on it, BUT I got an error msg telling me that this extension already exists, BUT again I couldnt find it neither inside the extensions manager nor the components!!
I have followed all documentations an tutorials regarding “Quickstart” and installed it many times on different machines and live host, but the same always!
Did I miss any thing?
TomC
TomC
- October 2014
- 3155 times in 2495 posts
August 28, 2013 at 11:13 pm #503830When you perform your quickstart installation – are you remembering to also install the sample data as part of the process?
If you did install the sample data during installation – then is the “nothing” you’re referring to the images that you find replaced by image placeholders?
August 29, 2013 at 11:43 am #503928Yes, I have installed the sample data.
My nothing refers to many things(the images, products, categories, SHOP menu, etc…), the most important is”Joomshopping” component, which is the only reason why I bought this template! I cannot find it the anywhere in the back-end and If i try to download it manually, it tells that this extension already exists!
Any help 🙂
TomC
TomC
- October 2014
August 29, 2013 at 3:10 pm #503965I believe that the confusion may be that while JA Fixel supports the JoomShopping component, the component is not included with the template itself – similar to how the template supports EasyBlog, but does not actually include the EasyBlog component.
The complimentary components that are included with the template are listed on the JA FIXEL INFO PAGE[/url]
Ninja Lead
Ninja Lead
- November 2014
- 3854 times in 3563 posts
August 30, 2013 at 3:58 am #504042@ghary90: you can follow this thread
AuthorPostsViewing 5 posts - 1 through 5 (of 5 total)This topic contains 5 replies, has 3 voices, and was last updated by
Ninja Lead 11 years, 5 months ago.We moved to new unified forum. Please post all new support queries in our New Forum
Problem: Installing JA Fixel !!!!
