test melih
 melih
Viewing 15 posts - 1 through 15 (of 16 total)
  • jsprague Friend
    #158449
    Ok, here is the issue, On my home page, I use K2 for my articles and for some reason, the pagination doesnt work all clicking on any of the numbers i.e. 1,2,3,4 etc… all go to page 1 as seen here:
    http://www.webkinzone.com/
    I am using SH404sef and wondered if this was the issue but then i tried switching for JA Social to JA Purity, all worked perfect. It appears to be an issue with JA Social.
    I have pruged my urls with SH404sef and have even turned off/cleared my joomla/t3 cache and still no good.
    Any help would be really appreciated.
    Thanks! – Josh
    #371085
    Dear jsprague,
    If possible please submit a ticket into our ticket system give us your admin account as well as the FTP Info for further checking on this issue.
    jsprague Friend
    #371150
    <em>@dathq 214020 wrote:</em><blockquote>Dear jsprague,
    If possible please submit a ticket into our ticket system give us your admin account as well as the FTP Info for further checking on this issue.</blockquote>
    Ok, i have done so. Thanks again!
    jsprague Friend
    #371221
    Hey so I’m not sure that your ticket system is working as I can no longer get in. Please look at one of my earlier tickets to see my ftp/admin info.
    Thanks!
    Anonymous Moderator
    #371272
    Maybe there is an unexpected error with connection at the time only. Kindly try using your registered email and password to login again: http://support.joomlart.com
    Let me know if you still fail for instant action.
    jsprague Friend
    #371340
    OK, i updated the username. Thanks!
    jsprague Friend
    #371681
    Hello! just checking in on this, been a couple days since any action was taken. Any idea as to why my pagination is broken as well as the comment counter n the home page?
    A few details:
    -Using the latest k2 for the homepage
    -Using the latest SH404sef
    -Pagination works perfectly on purity template.
    -Changes were made by JA support a little while back to correct some template bugs/style issue with my template (in case that contributed to this issue)
    -I also noticed that the pagination on standard joomla articles works fine. see here.
    http://www.webkinzone.com/Webkinz-Info/
    Update… Looks like comment counts are showing after all.
    Thanks again for your time!
    jsprague Friend
    #372046
    Just tried a new install on a seperate host using the Ja Social Quick start. The only thing I did was install and activate the latest SH404sef and the same pagination prblem occurs. This is only with T3 Templates though all other templates I have tried that are not T3 work just fine. Please help, I am getting desperate if I cant get this to work I will have to scrap all T3 Templates and that is not what I want at all.
    Thanks!
    Khanh Le Moderator
    #372805
    Hi jsprague,
    As my experience with sh404sef, you must set the parameter “List length” in Global configuration, site tab to the number of the article you want to show in your K2 page. Eg, in a K2 page, you show 3 articles in a page, you must set the “list length” in Global Configuration to 3.
    Tech-xml Friend
    #374758
    Anyone here have managed to solve this big problem?
    It has a forum post of mine for over two months without a solution.
    http://www.joomlart.com/forums/topic/bug-on-pagination-with-sh404sef-and-k2/
    Tech-xml Friend
    #374777
    What ta seeming is that nobody wants to see the existence or importance of the problem.
    The answers always come in a vague or diverting to other issues.
    What the support answers me is that the person who solves this problem is on vacation each year.
    Look at the date of my first post and see that now numbers more than two months the problem.
    There is no official statement on the issue of JoomlArt nowhere.
    The day I decided to take the problem to staff sh404SEF. They made a evaluation 2 hours and concluded that the problem is not in K2 and not in sh404SEF. It is a problem for the template T3.
    Call upon the Members of this community to strive to expose more of the problem you are experiencing. Maybe it’s the only way to draw attention to the problem…
    Khanh Le Moderator
    #375548
    Hi insofticursos,
    We are sorry for the problem you get. I’ve checked your site and but could not duplicate the problem. I reopen the ticket OER-354-61101 as your problem is not resolved. Please update the ticket with detailed description about your problem, then I’ll check and solve it.
    Tech-xml Friend
    #375706
    <em>@khanh le 219983 wrote:</em><blockquote>Hi insofticursos,
    We are sorry for the problem you get. I’ve checked your site and but could not duplicate the problem. I reopen the ticket OER-354-61101 as your problem is not resolved. Please update the ticket with detailed description about your problem, then I’ll check and solve it.</blockquote>
    I updated the ticket
    Please if you find a solution, I reported here, because I face the same problem with other templates JA.
    jsprague Friend
    #384335
    I wanted to make a comment on this issue even though I am late… I was able to fix this issue (kind of) by employing the following fix
    <blockquote>As my experience with sh404sef, you must set the parameter “List length” in Global configuration, site tab to the number of the article you want to show in your K2 page. Eg, in a K2 page, you show 3 articles in a page, you must set the “list length” in Global Configuration to 3. </blockquote>
    This works but is annoying. I am revisiting this issue because I am having the very same issue with the JA events template here
    http://www.clubpenguinnation.com
    In fact I cant even get the pagination to work with the JA events template using the work around above… I am using k2/sh404sef with other template clubs and there is never a problem. If there is any way we can get a real fix for this I would be grateful.
    Thanks! – Josh
    kyovev Friend
    #384630
    I have the same problem with the JASOCIAL template. I didn’t saw this topic and i opened new one…
This topic contains 16 replies, has 6 voices, and was last updated by  Sherlock 13 years, 10 months ago.
