test melih
 melih
  • giamoco Friend
    #156008
    Hi, I am setting up a website using Ja Purity and Megamenu.
    What I would like to do is to change the colors of the menu items AND the color of the submenus.
    I have also the “JA Menu Parameters” plug in working on the site.
    What is NOT working is assinging the color to the sub menus..
    I can get the new color of the menu voice (using the additional class on the Parameters (JA Extended) but NOT the color of the related sub menus /childs..
    I’ve tried to apply the same class to the sub menus but it is not showing any results.
    the web site is:
    http://www.sandalia.org/index.php
    and the example in the menu is called “test menu with color subs” (in Orange)
    any help / hint is more then appreciate!
    thanks in advance,
    greetings from italy,
    giamoco
    P.S.
    I’ve looked around in the forum but I have not find any solution.. in case ther’s already one pls forgive me..
    pierantonio Friend
    #361586
    Dai un’occhiata a questo sito francese: http://www.purity2.fr/fr/tutoriels/menus/mega-menu.html
    Buona fortuna!
    giamoco Friend
    #361597
    thx for the fast reply, but is not what I’m looking for..
    or at least not exactly..
    I would like to assign a different color to every single item of the menu:
    like having the first item (and sub menu) red, the second item (and sub) green and so on…
    any hint?
    It is possible from the admin panel or I’ll have to revrite the css by my self?
    giamoco Friend
    #361696
    no one?
    I’ll post an example just to show you what I’m looking for:
    http://www.oxfamitalia.org/
    I know, it is a WP site.. but I am sure that someone can do the same stuff for a joomla menu..
    still waiting for any help,
    thanks in advance,
    g.
This topic contains 4 replies, has 2 voices, and was last updated by  giamoco 14 years, 3 months ago.
