test melih
 melih
  • ipromenta Friend
    #984221
    In my site http://www.junnikkala.fi slideshow cuts description digits in mobile and tablet view!
    How to solve this problem?
    Pankaj Sharma Moderator
    #984329
    slideshow does not fully support the module view , due to its design .
    You can apply below tweak to make it good .
    Ipad : http://prntscr.com/d4gxqy
    Add this code in/css/custom.css file
    @media (max-width:768px) {
    .ja-slidewrap .maskDesc .ja-slide-desc a {
         font-size: 15px!important;
    this will reduce the font size , so it will fit in the smaller view .
    ipromenta Friend
    #984511
    Hi again,
    How can i change
    font size smaller in max660px view? Button that should be visible in every device view is hidden in smaller view handsets!
    Thanks!
    #984522
    just change the media query as
    @media (max-width:660px) {
    To hide the button use this code in custom.css file
    .ja-slidewrap .maskDesc .ja-slide-desc a.readon {
         display: none!important;
    ipromenta Friend
    #984528
    Hi, now there is a missunderstanding 🙂
    I really want the button to show in smaller handsets!
    #984653
    Hi, now there is a missunderstanding ?
    Remove the suggested code frim custom.css file and button appears again.
    ipromenta Friend
    #984737
    This is really getting frustrating!
    I really want to see all of description field in all mobile views!
    Slide title is too big and desription field is cut in small handset views!
    How can i modify this css to make them visible and smaller?
    I need answer ASAP!!
    Thanks!
    #984757
    Sorry in your last post it does not appear there is any issue .
    First, you have to remove the unwanted code from custom.css file .
    You added too much custom code in custom.css file .
    After this add my below code in custom.css file
    @media (max-width:768px){.ja-slidewrap .maskDesc .ja-slide-desc a{font-size:10px!important;padding-bottom: 15px!important;}
    .ja-slidewrap .maskDesc .ja-slide-desc a.readon {font-size:10px!important;top:100%!important;padding-bottom: 20px!important;margin-top: 13px;}
    After this step go to
    /templates/ja_biz/local/css/themes/junnikkala/mod_jaslideshow.css
    Add below code at the end of file
    @media screen and (max-width: 768px) {.ja-slidewrap .maskDesc {   width: 80% !important;}}
    Save file , clean Joomla and browser cache and check the site .
This topic contains 7 replies, has 2 voices, and was last updated by  Pankaj Sharma 8 years, 2 months ago.
