artemisgirl Friend
artemisgirl
- May 2012
December 15, 2012 at 3:42 pm #183134Hi
Please see my site: http://www.hermosatoursturkey.com – scroll all the way to the bottom where you will see “Turkey Top 5” and “why Visit Turkey”…. thes are the top hotels and top places modules with just a new name.When I originally set up the site I disabled these two because I wanted to get the site up and running in a basic manner quickly and so didn’t have time to make all the customisations that I needed to.
Now, I have more time, and I have gone and enabled them and renamed them and started to attach articles to them, but no matter how hard I try, I can’t get them to nest together (side by side with a tab for each one) as they did when I first activated the site, and as per the template rather than appearing one below the other as they do now… any ideas?
Stork11 Friend
Stork11
- March 2011
- 431 times in 393 posts
December 17, 2012 at 9:41 am #476479Hello artemisgirl,
You wanna place these 2 modules below “Latest News” module, right? If possible, would you mind getting me a few screenshots for more clarifications? Then I shall know what you are trying to achieve.
Regards.
1 user says Thank You to Stork11 for this useful post
artemisgirl Friend
artemisgirl
- May 2012
December 20, 2012 at 12:35 pm #476946Hi Stork
Thanks for your message – I am attaching screen shots of how the two modules are in the demo and how they appear on my site – I hope that clarifies things further…
Thanks-
Stork11 Friend
Stork11
- March 2011
December 21, 2012 at 2:58 am #477011Hello artemisgirl,
You need to publish “Custom HTML” module named “Content bottom” with content “{jatabs type=”modules” module=”ja_tabs” position=”top” mouseType=”click”}{/jatabs}”. Then put 2 JA ContentSlider modules to “ja_tabs” position. This will place these modules in tabs.
artemisgirl Friend
artemisgirl
- May 2012
December 23, 2012 at 2:08 pm #477280Thanks so much for your time Stork – unfortunately all of the settings are fine as far as I can see and the modules are published – any other ideas of things that I should check to troubleshoot this problem?
artemisgirl Friend
artemisgirl
- May 2012
December 23, 2012 at 2:16 pm #477284Hi, it’s me again – I finally fixed it and thought I would let you know what I did – I changed the settings to ja-tabs (instead of ja(underscore)tabs…because I am using joomla 2.5… thank you so much Stork for setting me in the right direction – I couldn’t have done it without you 🙂
1 user says Thank You to artemisgirl for this useful post
Viewing 6 posts - 1 through 6 (of 6 total)This topic contains 6 replies, has 2 voices, and was last updated by
artemisgirl 12 years, 1 month ago.
