test melih
 melih
  • whiteman43 Friend
    #164673
    I install tiIine IV in localhost and used this code in the custom css for font
    font-family: SolaimanLipi;src:url(solaimanlipi.eot);
    And the font size 6 in the global setting (As that local unicode font is too small to see.)
    After that the template look slight odd.
    I face some issue. Please help me to solve these issue.
    Issue no 1. How to change the font of the featured post on home page and how to enable the clickable content for that so that when user click on the content of the feature post they will be redirect to the post. at now the title only linkable? (Shown in the image mark as 1) and also how to change the font of the flash headlines on top (Shown in the image mark as 3)
    Issue no 2. How to change the font of this sub menu ‘s latest post. I changed the submenu font setting but it only change submenu 1st column not change the 2nd coloumn which show latest post. (Shown in the image mark as 4)
    Issue no 3. How to remove the publish date from the sub menu latest post? (Shown in the image mark as 5)
    Issue no 4. How to remove the top seach bar and last update bar?
    whiteman43 Friend
    #394423
    Please anyone help me. There is no support here! what happened to joomlart staff?
    mayuri_g Friend
    #394654
    Issue 1: to change the font of flash headline, in css file, you have to edit the class of headlines module, set the font-size there and save the file.
    Issue 2: To change the font of submenu , you have to created submenu by adding module as a menu to main menu, so when you create modules , set show tittle No and in the Editor Type your Submenu Tittle with the font whatever you want.
    Issue 3: to remove publish date, you have created aricals and added them to Latest News module, so when you create articals ,
    in Partameter (Advanced), Created Date and Time set Hide and Modified Date ,Time set Hide.
    Issue 4: To remove top search bar, in module manager , set search module Enabled No.
    whiteman43 Friend
    #395134
    <em>@mayuri_g 244831 wrote:</em><blockquote>Hello,
    Issue 4: To remove top search bar, in module manager , set search module Enabled No.</blockquote>
    Can you please explain the ans so that i can understand? I am totally a newbie to joomla.
    One of my question was hoe to chage the font of the features news?
    mayuri_g Friend
    #395177
    You might have created flash headline module and added articals of headlines to it to display random headlines ,
    when you craete articals in the editor set the font-size as you want,then create artical and add that articals to module.
    you might have to created module for Latest News, Featured News. When you create modules ,
    And you also want to change the font of Latest New module’s submenu’s font, do the same way
    that articals to Latest News module. then font will incease as you want for mark4 in the image.
    you have created articals for Latest News module , added them to Latest News module,
    so when you create articals , in Partameter (Advanced), Created Date and Time set Hide and Modified Date ,Time set Hide.
    Issue 5: To change font of Featured news module,
    you have created module for Featured News. When you create modules ,
This topic contains 5 replies, has 2 voices, and was last updated by  mayuri_g 13 years, 8 months ago.
