test melih
 melih
  • sodobe Friend
    #142491
    I have the same problem with this topic.
    http://www.joomlart.com/forums/topic/collapsible-modules-second-problem/
    I use Joomla 1.5.9
    Here is my website url: removed!
    Thanks for supporting.
    PLease remove my website url after supported.
    sodobe Friend
    #310114
    please check the problem.
    Thanks.
    Anonymous Moderator
    #310145
    Hi sodobe
    I checked your website but coudl not find your issue. It is working fine.
    Did you fix this issue?
    sodobe Friend
    #310147
    <em>@JA Developer 135586 wrote:</em><blockquote>Hi sodobe
    Did you fix this issue?</blockquote>
    Thanks for reply but actually I didn’t fix anything.
    Please recheck carefully.
    The first time, you have to click on it more than one time to open. After that, it’s alright, but I mean the first time you open the website.
    sodobe Friend
    #310333
    no one cares bout this problem?
    sodobe Friend
    #310739
    There is no JA Developper member knows how to fix this problem, isn’t there?
    Sorry if it’s offensive but It seems like that.
    sodobe Friend
    #310962
    Sorry if you consider this as spaming. I apoligize for that. However, I really dissapointed about the customer service of Joomlart. I changed the template.
This topic contains 7 replies, has 2 voices, and was last updated by  sodobe 15 years, 6 months ago.
