test melih
 melih
  • nyarla Friend
    #158694
    Hi all..
    I’m starting using T3 framework, it’s great but i’ve a very big problem.
    When I try to add a separator menu item or an external link item i’ve a wrong visualization, so I can’t use the separator in the correct way…
    If I disable JA T3 Framework Plugin everything work..
    I tried with firefox and IE8, but the problem it’s the same…
    Any Idea?
    Here the screenshot
    1. screenshot
    aman204 Friend
    #371722
    Do you wish to refer to screenshot where admin backend layout is breaking in your case if separator menu type is selected ?
    nyarla Friend
    #371752
    <em>@aman204 214832 wrote:</em><blockquote>Do you wish to refer to screenshot where admin backend layout is breaking in your case if separator menu type is selected ?</blockquote>
    Yes, this is the problem, if I’ve understood your post.
    1. I create a new menu
    2. I add a new item, choosing the separator item (1.png)
    3. This is what result (2.png)
    If i try to use it and save it, i’ve 7 output of the same module.
    Thank you!
    1. 1
    2. 2
    aman204 Friend
    #371884
    Seems like it is due to some core joomla files corrupt or missing
    Please try to re-upload core joomla files from unzipped joomla package or to troubleshoot, You can have clean install of joomla package with blank T3 template and selecting specific menu type will appear fine
This topic contains 4 replies, has 2 voices, and was last updated by  aman204 14 years ago.
