test melih
 melih
  • glennbmx7 Friend
    #989111
    When I try to edit a "JoomlArt Advance Custom Module" it goes to a blank page with just the option to change the order.
    Log in details are added in this post so you can see what I mean.
    Thank you for your help!
    glennbmx7 Friend
    #989112
    Actually seems to be with any module, not just the Advance custom module. Any help would be appreciated.
    Thanks!
    Pankaj Sharma Moderator
    #989135
    I checked ACM module and its working fine : http://prntscr.com/db27cl
    Kindly clean your browser cache and check it again .
This topic contains 2 replies, has 2 voices, and was last updated by  Pankaj Sharma 8 years, 2 months ago.
