I've created VM Categories: Computers > Laptops
One product from default demo show in it (by changing its category to Computers, Laptops)
But any new product I create inside it, does not show, what could be wrong?
https://snag.gy/8s9YRO.jpg
warylad Hi. Please tell me the url to the page where I will be able to check this issue. Are You using multilanguage option?
teitbite I have updated site URL
I did index all in JAmegafilter and the new products entered, just showed, it means that after adding each product we have to do it? Such a nagging feature...
any non repetitive non cron instant/auto way of doing it?
warylad Hi. If that's the case than I'm afraid You will have to disable indexing, but this means filter will run way slower.
Ok i'll look which is better option but at least it shows for now....
However encountered another blocker issue, please see if you help solution on this separate issue..
https://www.joomlart.com/forums/d/23882-error-please-choose-a-filter-menu
warylad You can try with cron job feature of JA Megafilter: https://www.joomlart.com/documentation/joomla-component/ja-megafilter#cron-jobs It will allow to index automatically in defined duration
