This topic contains 4 replies, has 2 voices, and was last updated by mhp 7 years, 2 months ago.
The topic ‘theme problem’ is closed to new replies.
Do u want to show the same module and layout?
The layout is set by thre template style please check the news2 menu using the same template style like news menu.
If i am not getting your issue please share some more details so i can suggest better.
Yes exactly I want to show the same module and layout. Both are using the same template style in my opinion. Could you quickly login and have a look?
regards
On this page http://server1.masterhomepage.ch/~pianov/index.php/music-news-2
You are not using sidebar module like on news page so images are big.
And you are not using same ACM header module.
Open module manager > position : acm-header. if you want to use only one acm header module kindly set it to all pages and unpublish other acm modules.
On news menu its acm module with iD 554.
Hope it helps.
