  • dlenna Friend
    #1024161
    Hello, I have a problem with the module Slideshow CK. I cannot make it works with your template. Even if I select the slideshow position it doesn’t work. I tried with Joomla default template and it works, so I think there’s some conflict with Purity III. I have a multilingual website, I set off the language switch template thinking it could cause this problem, but still the slideshow didn’t appear.
    Can you help me please?
    Thank you,
    Anna
    Could you send me the page that slideshow module showing on your site? As I can see on the homepage, it doesn’t render there.
This topic contains 1 reply, has 2 voices, and was last updated by  Saguaros 6 years, 11 months ago.
