  • mickmackk Friend
    #880732
    Hey together,
    I would like to customize features-intro style 9 a bit, but like to keep the orginal. So I copied the style-9.php, style-9.xml and style-9.less file in "uber/local/acm/features-intro/…" and renamed each of them to style-91.*
    I made all the necessary renaming within the files as well.
    The problem is: Once I try to translate the less into css my new style-91 is not considered. So as result it is not included in the final style.css.
    Do I have to register my style anywhere else?
    Ninja Lead Moderator
    #881150
    This is a problem from your custom work and it’s out of JA support scope but you can try to have a look at my screenshot, you will see style-91.less file is loading style-9, you need to change it with new style.
    Besides that, you can follow the guide how to make the customizing style of ACM module
    1. Screen-Shot-2016-02-11-at-10.32.18
This topic contains 1 reply, has 2 voices, and was last updated by  Ninja Lead 8 years, 2 months ago.
