April 19, 2017 at 3:56 pm #1027509
Hi, I have bought ja-wall template and install k2, I found that when I create menus using k2 tags, ja-wall give me a layout which is different with the menus using k2 categories, why and where to config them?
Thanks.-
April 20, 2017 at 8:14 am #1027683Hi,
Could you share the admin login info of your site so I will take a look?
April 21, 2017 at 5:44 am #1027880This reply has been marked as private.April 21, 2017 at 5:49 am #1027882This reply has been marked as private.April 22, 2017 at 5:38 pm #1028122Any body can help me?
Saguaros ModeratorSaguaros
April 24, 2017 at 6:56 am #1028414Hi,
Here are my answers for your questions:
2D Games menu item:
It’s K2 Tag menu type and display K2 items which has same tag. You just need to access Admin panel > Menus > SidebarMenu > 2d Games and configure as you wish.
To change the number of items showing under this menu, you need to set via Parameters option under K2 component: http://prntscr.com/f03vy9
All Games menu item
In this menu item setting, you set to show K2 items from only one category called IO Games, so it will inherit settings from this K2 category. So I go to K2 component > IO Games category and set template ‘JA WALL’ for this category: http://prntscr.com/f03ws9 and it’s showing horizontally now.
You can change the ordering or other parameters under settings of this category also.
Let me know if you need further helps.
Viewing 6 posts - 1 through 6 (of 6 total)This topic contains 5 replies, has 2 voices, and was last updated by Saguaros 7 years ago.
