June 14, 2017 at 3:20 am #1041727HI George,
I tried to edit article from front-end of Purity III template based site at my end but it worked properly: http://prntscr.com/fjieo8
You can share the credentials of your site: URL, Admin + FTP account so I will take a look.
June 14, 2017 at 3:54 am #1041736This reply has been marked as private.Saguaros ModeratorSaguaros
June 14, 2017 at 4:14 am #1041745The account seems not work, kindly check again.
And guide me the steps to log into frontend of your site as I’m not familiar with your native language
June 14, 2017 at 4:16 am #1041746This reply has been marked as private.June 14, 2017 at 4:23 am #1041749This reply has been marked as private.June 14, 2017 at 11:03 am #1041810Any luck?
June 15, 2017 at 4:39 am #1041974This reply has been marked as private.Saguaros ModeratorSaguaros
June 15, 2017 at 4:48 am #1041977Hi George,
It looks like that navbar for tabs can’t be rendered. As I can see there is JS error on edit page and it may cause the issue: http://prntscr.com/fjxzr8
I suggest you disable 3rd party extensions on your site one by one first to see which one caused issue as I tried to edit article at my end but it works properly.
June 15, 2017 at 5:04 am #1041980I knew that there was a JS error, but when I switch to protostar template, the tabs navbar renders fine. That’s why I thought it is a JA purity issue.
June 15, 2017 at 10:53 am #1042067Because when you switch to protostar template, there is also no 3rd party extensions used there.
June 15, 2017 at 11:02 am #1042068I am confused. I thought 3rd party extensions have nothing to do with templates. The only 3rd party extension that is used is the template itself.
I mean that the only extra extensions that are loaded when enabling JA Purity III is itself and T3. Everything else looks just the same.- This reply was modified 6 years, 10 months ago by George.
June 16, 2017 at 8:14 am #1042291I can see that there are several 3rd party extensions used on your site with our template. I meant that when using these extensions, which may also loads its own JS and caused the conflict as screenshot above.
And you can try to install our template in a test site with Joomla package only, you can see the editing feature still works properly.
June 16, 2017 at 8:31 am #1042299Yes, but those extensions are loaded also when I use the Protostar template, with no problems or conflicts at all. The conflicts occur only when using JA Purity III. In all forums that I visited about this kind of issue, they say that "if everything works fine with Protostar, then it’s a template issue".
I cannot delete plugins which are working fine with other templates or with each other, because JA Purity III has conflicts with them.
Thank you anyway. -
This topic contains 23 replies, has 3 voices, and was last updated by George 6 years, 9 months ago.
The topic ‘Frontend article editing tabs problem’ is closed to new replies.
