August 1, 2017 at 7:31 am #1052936
Since a couple of weeks in the frontend, when i try to create an article the editing tabs aren’t available anymore.
So I found out in this forum to reïnstall the T3 plugin but now I have this problem:
The Article-form is displayed, still without editing tabs,.. There is no layout.
And under the form I got this error: 0 – Cannot use object of type ContentViewForm as array
Saguaros ModeratorSaguaros
August 2, 2017 at 4:05 am #1053137Hi,
You can share the credentials of your site and the article page I can replicate the issue. I will take a look.
August 2, 2017 at 9:19 am #1053244OWkey now i can answer here also,. Send you the credentials via Skype.
August 4, 2017 at 2:45 am #1053649This reply has been marked as private.August 4, 2017 at 6:48 am #1053693No such extension, would an remote desktop be suitable?
August 4, 2017 at 7:17 am #1053704I have a mirror site running. I teste it on it now and the problem started by updating de T3 system plugin to 2.6.6 On the mirrorsit witch wasn’t up to date i started from version 2.6.2
August 4, 2017 at 7:28 am #1053709In the mirro version I place back the 2.6.5 an its OK. In the real site I still have a weird form wirh
"0 – Cannot use object of type ContentViewForm as array"August 4, 2017 at 8:15 am #1053732GREAT I Found the sollution on this forum
https://www.joomlart.com/forums/topic/bug-found-in-t3-2-6-5/AuthorPostsViewing 8 posts - 1 through 8 (of 8 total)This topic contains 7 replies, has 2 voices, and was last updated by joerif 6 years, 8 months ago.
Frontend article editing tabs problem’
