The landing makers Friend
The landing makers
- January 2017
September 7, 2017 at 3:32 am #1060918This is the thing:
- 1.- Joomla was installed in a folder named "/landing".
- 2.- JA Builder was succesfully installed.
- 3.- The "/landing/website-basico" (a JA Builder page) was set as joomla’s home page.
- 4.- Joomla was succesfully migrated and configured to run in the new "/" path.
- 5.- A new JA Builder page was created and set as the new joomla’s home page.
- 6.- The JA Builder page "/landing/website-basico" was deleted.
- 7.- Now there are a some of duplicated code lines just as two tags.
Because of this issue, and despite that each JA Builder pager and each conventional Joomla page has it’s own name every page in Joomla has the same title "Landing" and Google’s search machine is not indexing the different contents.
This issue only appears when the The Universal Builder is enabled. I looked into the configuration files and found no reference to the "/landing" folder.
I hope that you can help me whith this.
- This topic was modified 6 years, 6 months ago by The landing makers.
The landing makers FriendThe landing makers
- January 2017
September 7, 2017 at 3:36 am #1060920This reply has been marked as private.The landing makers FriendThe landing makers
- January 2017
September 7, 2017 at 3:38 am #1060921This reply has been marked as private.Saguaros ModeratorSaguaros
September 8, 2017 at 4:12 am #1061130Hi,
You can share the credentials of your site so I will take a look.
When you move site to a new directory, pls try to access and export the page under ‘/landing’ directory then import into the site in new directory.
- January 2017
September 8, 2017 at 6:08 pm #1061223This reply has been marked as private.Saguaros ModeratorSaguaros
September 11, 2017 at 4:19 am #1061373This reply has been marked as private.The landing makers FriendThe landing makers
- January 2017
September 11, 2017 at 4:54 am #1061380This reply has been marked as private.Saguaros ModeratorSaguaros
September 13, 2017 at 9:01 am #1061757Could you share ftp account also?
- January 2017
September 13, 2017 at 6:16 pm #1061907This reply has been marked as private.Saguaros ModeratorSaguaros
September 18, 2017 at 4:52 am #1062598Hi,
I’d like to check how the configuration file is set up as the base URL is still redirected to that ‘landing’ directory.
Could you check the FTP account again? as it points to blank directory now.
- January 2017
September 18, 2017 at 2:33 pm #1062686This reply has been marked as private.The landing makers FriendThe landing makers
- January 2017
September 18, 2017 at 2:35 pm #1062687This reply has been marked as private.Saguaros ModeratorSaguaros
September 26, 2017 at 3:30 am #1064074Could you check the FTP account again? as it doesn’t work now.
I will check with the team for this issue.
- January 2017
September 26, 2017 at 2:21 pm #1064200Hello,
The FTP account is working ok from my side and takes you to the right place.
But never mind. After 18 days of waiting for a solution and since building the website from scratch will only take about two days we’ll go for this and rebuild the entire website.
I understand that I’m not a Premium user and therefore I won’t get support within the first hour after posting an issue, but to wait so many days for an answer is quite frustrating.
Nevertheless I think that the JA Builder is a good product. If you could improve your support timing you would be awsome.
if I happen to have another issue I’ll let you know.
Thank you.
This topic contains 14 replies, has 2 voices, and was last updated by Saguaros 6 years, 6 months ago.
