I have a small issue with Hello Me module. Forgot username, Forgot password, Resend activation link are all showing in the same line as you can see in the attachment.
any suggestion how that can be fixed?
ad4x4 Hi it depends on the space of module position, if there is space it will move to right. If there is less space the links show below each other. May i know how you would like to display them?
I would like them to be below each other not on the same line. Ninja
ad4x4 Hi As suggested by Paul, add this code in your template folder /css/ template.css file or any other css file of template
.joms-form[name="login"] .joms-gap+a { display:block } .joms-form[name="login"] .joms-gap+a+a { display:block; margin-top:-1.5em }
It will look like this http://prntscr.com/kumd83
Can you try
Cheers Paul
Thank you guys. Appreciate the support.
ad4x4 You are welcome!
