Since the update, there is a problem displaying "True and False". With some quizzes it looks good but some ones show GURU_QUESTION_OPTION_VRAI or GURU_QUESTION_OPTION_FAUX (Vrai=False and Faux=True in French) on front-end. Nevertheless, the display is sometimes good. Thanks Eric
Arvia Hi it can be issue in your translation file of french, Kindly open /language/en-GB/com_guru.ini and find the constant : GURU_QUESTION_OPTION_VRAI check the value for it. If issue still showing on any quiz, kindly share a login details of student so i will have a look on it.
I don't have the constant GURU_QUESTION_OPTION_VRAI in /language/en-GB/com_guru.ini
I have only : GURU_QUESTION_OPTION_TRUE = "Vrai" GURU_QUESTION_OPTION_FALSE = "Faux"
Here with login of my student (private)
Thanks Eric
Arvia Hi I am not able to replicate this issue in current student courses : http://prntscr.com/kj57vn I tried multiple fields but its not showing any language constant.
sometimes the display is good and sometimes it is bad. See screen Shot. Thanks
[](http://)
Arvia Hi I tried a no. of times but its showing fine. I will take a round again on this to check it again and update you.
is it possible to send you a hidden link with a problematic page ?
Arvia Hi You can edit fields in first post and submit the link. I will also check that link on your site.
Arvia Could you confirm if you still have this issue? After adding
GURU_QUESTION_OPTION_VRAI = "Vrai" GURU_QUESTION_OPTION_FAUX = "Faux"
I have the same problem ; I solved by adding GURU_QUESTION_OPTION_VRAI = "Vrai" GURU_QUESTION_OPTION_FAUX = "Faux"
/language/my-MYLANG/com_guru.ini
