Hi team, a client asked me if it is possible to move the "read-next" location to the right, is it possible to make that change? Is there any tutorial or some information? (Attachment screenshot)
vgutierrez2012 Hi
It looks like you moved it to the right side already:
Yes, I wanted to make some modifications, but in cell phone view I had problems, so my question would be, is it possible to change the "read-next" position to the left, or in any case, is it possible that the sidebar is below the photo?
vgutierrez2012 You can simply go to Layout settings in template >> drap&drop the position of sidebar and component block in mainbody section as you wish.
Another problem that occurred was when I updated the T4 Framework plugin and out of the blue the template does not load the "custom.css" file.
Could you check please?
vgutierrez2012 I tried to add sample css code into the file:
/templates/ja_purity_iv/local/css/custom.css
and it loads normally.
Kindly check again.
saguaros Hi Saguaros, I tried it, but when I activate a module in the "sidebar" position it doesn't stay below the photo, it stays at the same height as the photo, I would like it to stay below, as it happens with "read-next" (Attachment screenshot)
vgutierrez2012 I don't get your point here, could you share screenshot of how you want it should be?
Hi Saguaros, when I activate a module in the "Sidebar" position, it is on the right, but it moves the title of the article and the image, I attach a screenshot:
What I need is for the "sidebar" position to be below the image, I attach a screenshot:
vgutierrez2012 I got your idea but JA Purity IV doesn't this kind of layout for article by default. You will have to customize the layout of article to achieve that.
Based on the layout you're using, you will customize associated PHP file in this path:
root/templates/ja_purity_iv/html/com_content/article/
