cssyeah that's almost perfect ... BUT ... on listings in shop if the listed product custom fields are long, the text don't split as it should
. take a look and advice ! ... Thank you in advance !
P.S.1 there is another css issue with the language flags swich, where in the dedicated position for the module don't show in line with cart and off-canvas menu ...
( I think the programmers forget to check in template the module in that position ) ...
P.S. 2 ( how can I add you as friend ? 🙂 ... to please you guide in future for some custom css need it )
