If I delete the containers, the head works normally.
I have two examples here:
Pages without containers: https://seo-schweinfurt-relaunch.de/eiche-schnittholz/riftschnitt
Here the header is exactly as it should be and the text in the drop down menu is formatted on the left.
Pages with container: https://seo-schweinfurt-relaunch.de/eiche-schnittholz/saegefurnier-eiche Look at the head height and also the drop down menu
Why can that be
Kind regards Thomas
Hi Thomas,
May I know which container are you referring to?
Where did you remove it? You can share the login info so I can take a look as well.
