I'm working on a web site using JA Findus template and CW Multicateogories extension and I have discovered a problem between "T4 Framework" and "CW Multicategories" and I don't know if is a but on T4 or on CW Multicategories.
This is the problem: if "System - CW Multicats Plugin" extension is enabled then T4 Framework "Listing Fields" don't show in article back end.
I've attached two JPG:
- "jt-admin-article-edit.jpg": Shows T4 Framework "Listing Fields"
- "jt-admin-article-edit-no-listing-fields.jpg": T4 Framework "Listing Fields" don't appear
It seems that your extension thinks it belongs to some specific category and that's why it doesn't show it, but they are not custom fields from joomla core but from T4 Framework. Maybe "Listing Fields" are stored like custom fields, I don't know.
We need those T4 Framework "Listing Fields".
¿What can I do?
Than you
