Hi, I just found a problem and thought it may be a recent update, but not sure when this started. It has been working for a long time.
I am using the ACM module to create this food menu listing. It works correctly on the default tab (Plates), but all the other tabs insert multiple blank items that push down the actual items it should be listing directly under the menu tabs (snapshot attached). I looked through the ACMs that build this and I don't see anything changed, but using Browser Inspect, you can clearly see several items that appear to be the first tab (plates) being listed, but the text is not displayed, and then the items get listed way down the page.
