I've a strange problem on a website. where I've installed the template JA Education since a long time ago and it works fine.
Now I'm trying to install new template (https://www.themexpert.com/joomla-templates/morph) to use it for creating and building some new landing pages. The problem is that when I try to activate the template it request to activate T3 plugin. If I Install and activate the general T3 plugin, the templates doesn't work.
I've written then to the developers (giving them the access to our backend) and they told me that:
"It seems your template uses a different version of T3, and when enabled, the standard version doesn't work and that is why you can't get the Morph theme open. When only T3 is enabled (https://d.pr/i/BYpoBZ), Morph works properly (https://d.pr/i/h6d9pn).
Please contact your template developer and ask them about the T3 framework version they are using."
Can you please help me to solve it? In fact the new templates works only If I deactive the JA T3 Framework :
Thanks,
Niccolò
