Dear Joomlart, Hide Title Module not work! When I create new module and option hide title, it is not work 🙁.
Thanks your help!
naphnamservices Hi May i know the module position ? Try this : Go to module > advanced tab > module style > inherit. change it to xhtml and save.
Ninja
Thanks your help I select from module option. And choose xhtml but not work !
naphnamservices Hi Kindly choose the option from Layout options since its choose by layout, if still not work kindly put the site online and submit site login in edit fields options.
Thanks you!
I find issue, this module cannot hide title, I try with another module work. Thanks you!
naphnamservices Welcome!
