Thanks; the problem is in the module: if you check, there are a lot of "returns" in the text space over the image; if I delete them, the image is not shown anymore.
If enter only two returns I can see the image only for the height of 2 lines of text.
On section 8 there is no text on the image module.
Also, if you use a 4K large screen you see the image 2 times, one beside the other and that doesn't occour on section 8.
I also have a problem with the contacts section (need the fields to stay open) but idk where to modify the options... Do I have to open a new thread?
