Hello
I'm using sp page builder pro version with the version 1.0.2 of T4 framework.
I have an issue with css animation on this page with these parameters :
class="sppb-section sppb-wow fadeInRight"
animation-duration: 600ms;
animation-delay: 3ms;
https://freget-associes.fr/2020/FR/test
No problem with the slideshow but under it, two section must slide from the side but when I activate the animation, I have a blank space unstead.
You can check it here the version with no animation :
If I switch to another template like protostar the problem is solved and when I desactivate the animation also.
So, It's really a problem with T4.
Can you please help me to solve this ?
Thx a lot
Eric
