hello saguaros i send a message that includes all the above messages so as to avoid confused .
First of all the credentials are ok ...try again ...i tried them and everything was ok .
Description of the problem :
I had installed some verticalmenu modules in different pages of the site in sidebar positions ..They are operated in this position without a problem .But the last 4 days removed ........and the problem is that also removed the sidebar modules positions in order to install again in these positions .
In order to explain in a more analytical way , the operation and my movements...First of all i will show where do you find the vertical menus modules :
Go to administrator panel in extensions / modules and choose select type from dropdown menu .
Choose vertical menu (it is the name of the module ) I have about 24 vertical menus .from id 222 - 245 As you see the were showed in the position sidebar.
These vertical menus modules were joint with the menus items in positions footer 1 footer 2 footer 3 with menu items . I mean that every time you click to these menu items in order to see the content of the article , i this page i had the vertical menu to appear until now .
In order to help these items menus had id 285 -307 (these are in the menu items tab in the poitions of footer 1,2,3 positions )
They are showed up to now with no problem .
Suddenly stopped to showed in the front page ..And as i see these pages dont;t have position sidebar ....
In order to help more you i will give you an example of a page in which i would like to have the vertical menu .
(it was showed in this position but suddenly dissapeared ) .
In the administration panel the vertical menu with the name
Ε.Σ.ΠΕ.Ε. Β. ΤΟΜΕΑ ΑΘΗΝΩΝ (position sidebar and id 244 ) is joint in the menu item with id 293 (the page have to be showed is the following :http://energyinfraheat.gr/index.php/2019-10-14-09-02-50
In the same way also the other vertical menus have to be showed to the same pages like this , of menu items of footer 1 ,2,3, but all these menu items pages have the same problem .The have their side bar modules positions removed .( the problem is that i had in the same page of these menu items the vertical menus of them installed before 4 days and they didnt have problem ..everything was ok with them ).
Try to recall the modules positions sidebar in all these pages in order to have all the vertical menus to operate again .
Please send me your guidelines .
Sorry for all this incovenience .
With regards
George
