It seems if I add things to my cart and then delete it, when I go to Checkout, the items appear back in the cart.
Please investigate ASAP! I'm on version GURU 5.2.1 Thanks.
Please test now, I made some changes in Guru files: /components/com_guru/js/buy.js /components/com_guru/views/gurubuy/tmpl/default.php there was an issue with AJAX call request. All these changes will be added in the next Guru version.
Kind Regards, Alin
